Hello,
I’m trying to route the main mix of an SQ7 over tie lines to an SQ6. I only see a way to route console inputs, either local or from the SL Link to the tie lines. is there a way to do this?
Hello,
You connect the two SQ via SLink, route on the SQ7 the main mix to SLink outputs, which will be SLink inputs on the SQ6. On the SQ6 you can route this SLink inputs to local outputs via tielines.
Yes it can be done. Connect both mixers with SLink Ports.
Then go to your IO Page and patch the LR Mix of SQ7 to the SLink SQ6 of your choice. For Example Slink 11+12. Now your Main LR on the SQ7 is outputing on your SQ6 11/12
https://www.allen-heath.com/media/SLinkConnections_V1_4_0.pdf
