If I remember correct it’s called something like “send assign”
Source should be the channel
destination is the mix you wish to toggle the assign on or off
will check it later if I’m right…
thank you, that worked.
Could you share this config with me for use at my church? it would be a huge help to build mine off what you created. THanks!
ADMIN login can control all mixes in horizontal mode and master volume & click track in vertical mode. I also put some essential HOUSE controls (pastor’s mic, my mic, house music, etc) on a tab in vertical mode.
Enjoy!
(I am sharing via Dropbox since the file is just shy of 5 MB. The limit here is 1 MB.)
https://www.dropbox.com/s/1ohc85t92wcjzcn/220226%20Fixes.xml
