Master rack in Dual rack setup
I read that the Master rack in a dual rack setup must be fitted with an ACE card an must be connected to the surface.
I want to know if it is possible to connect the surface to the slave rack fitted with an ACE card, which connects to the masterrack.
I want to do this because I want to fit the master rack with an MMO card. (The slave rack is in the orchestra pit and I want to record using ADAT). I am testing this configuration now and I think it works?
Does anybody have any experience with this configuration?
Eric
T112 & iDR-48 & iDR-32 & Iphone & Ipad2 & PC & MAC
Hi Eric
The configuration you have described is not valid i’m afraid. With a Dual Rack system you must connect the master Mixrack PortB:ACE to the slave mixrack Primary ACE port with a T-series fixed format iLive system like you have.
I’m afraid you will have to fit the MMO module to PortB of the slave mixrack and send audio you wish to record out of Port B:MMO of the slave mixrack.
Regards
Sam A&H
Hi Sam, Thanks for the answer.
Regards,
Eric
Hi Ecombrink
You could expand your dual rack system by adding an expander to master mixrack PortB Link2. You could then place the expander somewhere near your ADAT machine for some extra analogue inputs/outputs and Place the MMO mudule in PortB of the expander for recording, while your slave rack still remains in the Orchestra pit.
Please note: make sure PortB ACE redundancy is ‘Off’ if you wish to set this up.
Hope this helps
Regards
Sam A&H
