I noticed that the matrix (both stereo and mono) has a lower signal output than the main LR output (both stereo and mono). I tried turn off all EQ, compressors and it was still the same. If I want the same signal, I have to send to the matrix Main LR about +4dB more. I was afraid that there is also a loss frequency, but not. It only has a lower signal.
In this show there are three stereo matrix and main LR. Main LR is only a “sending” to matrix. When I got to speakers Main LR, signal and volume was higher than when I got to speakers LR Matrix. And meter of Main LR was higer than Matrix LR.
When I get my GLD demo back I want to setup and test this with tones and noise and a program. I did notice on a couple of installs that with a matrix feeding the usb recorder I had to crank it up beyond unity to get a decent level especially on pastor’s sermon. I think I remember winding up with a compressor engaged with a level bump and tight threshold for several db of compression to protect recording. I just never took time to test the levels to see if the matrix circuits run lower.
Noticed this 6 month ago and then informed my distributor.
This when LR was sent to two different steriomatrixes. They came out with 4 db difference.
No compressor engaged.
Confirmed twice that the LR was set to unity on both matrix sends.
Took the show file to another GLD to confirm not to be hardware issue.
I wondering if this has something to do with a dB offset when summing the L&R to a mono matrix. I don’t know that this is an option on the GLD but I have seen it before on metering when summing signals together.
