Is the routing of Input Channels to Matrices something new with Avantis? It certainly isn’t an option on SQ and from what I can see it isn’t on dLive either.
This caught me by surprise when I was duplicating some of our SQ broadcast setup on our new Avantis and found that all Input Channels were available as Matrix inputs as well as Groups, Aux and Main mixes.
One thing which would be nice would be allowing use of the Assign and Pre keys to add/remove inputs from a Matrix and change Pre/Post settings, and especially being able to do that for all inputs by tapping the Matrix Mix itself (same as with other mixes).
input to matrix is possible on dLive already
OK, must have been an old tutorial I found.
PS. Are there any signal flow block diagrams for Avantis? Couldn’t find any so far.
@cvenn
Would be nice but AH does not give us those.
They give us some block diagrams but you have to make your own signal flow to see what is happening.
They supply them for the SQ.
I expect they will add them in a future Avantis reference guide.
@cvenn
a complete signal flow for all possible paths on one diagram ?
I don’t recall saying anything about one diagram.
@cvenn
I find it very hard to follow signal flow unless it is on one diagram not scattered over many pages, and would not call that a signal flow diagram although I suppose I could cut and paste one together from those if I had to.
Thank you Jack for the block diagram in the latest firmware doc. I knew you would come through!
I must admit, it was just a copy and paste job on my part!
@Nicola A&H did the actual work of making it!
PS. Are the double/triple lines on the diagram deliberate?
It looks quite blurry to me. Maybe it’s my old eyes !
