Matrix to Main
Is there any way to send my Matrix back to the Main Mixbus? I created a work around sending my matrix to an FX In bypassing the FX and sending it back to the Main Bus. Does anyone have a better idea how to solve my problem? or is there any way to send multiple groups to one specific group?
Thanks for your comments!
Normally a matrix is still behind the main sum. Therefore you can sum up main and subgroups (and also inputs) here.
But you can easily get a matrix back into normal inputs by simply selecting the desired matrix as source in the preamp. From this input you have all possibilities again.
To send groups in groups, which is normally not useful, you can use the same trick by going back to inputs.
