Hello,
I own a qu16 and i need an IEM system for our band. We need at least 7-8 stereo mixes so qu-app is not an option. We are between ME-1 and movek mymix audio, with the first choice seems easier to feed directly from the dsnake output.
Our concerns are:
- ME-1 has no eq/tone control per channel (like mymix)
- There is no global effect (ex. Reverb) to the unit to mix with each channel as desired.
- Mymix can feed local inputs to the network (as extra inputs)
BUT the main advantage of ME-1 is that we can feed directly it from the dsnake without additional cabling, costs etc.
Lets get to the point. Is there a possibility to implement the above scenario?
Example: We have 5 vocal mics used simultaneously (channel 1-5) and we use FX1 as a reverb for FOH. On ME-1 if I open channel 1-5 and FX1 return I will hear all mics with reverb right? Or if I open channels 4-5 and FX1 return I will hear ONLY mics 4-5 with reverb?
Another example: Four different musicians with ME-1’s want to hear the above scenario is that possible?
Musician1: vocal 1 with reverb, vocal 2 dry, guitar with reverb, snare with reverb
Musician 2: vocal 1 dry, vocal 2 with reverb, guitar dry, snare dry
Musician3: vocal 3 with reverb, vocal 1 dry, snare with reverb, toms with reverb
Musician 4: vocal 4 with reverb, vocal 1 with reverb, vocal 2 dry, snare dry, toms dry, guitar with reverb
We are very confused about how can we have the desired fx level on every ME-1 individually. This solved very easily with mymix as there is a global effect on the PSM so no need for fx from the feeding console.
