Greetings – can the ME-1 drive an output on my iDR-32? You know, for a muso on a wedge instead of ears. Thank you!
Why not connect the wedge amp to the ME-1?
Tim,
The ME1 does have a TRS mono out so it would be easy with a patch cord. The question might be how much latency the whole path would have with another loop through the rack.
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad2
Thanks, guys. I was hoping to use the ME-1 as a remote mixer. You’re both absolutely right, I can run the balanced mono output back to the amp.
Gotcha…I was thinking you wanted to use the ME-1 by patching it back through the rack and use a parametric or graphic and then on to the wedge.
Scott
iDR 32
iDR D-Out
MMO
