ME-1 shows audio but no output to headphones
We have 8 ME-1’s that we normally run from a Me-U Hub. Our hub went down so we daisy chained them directly from our A & H idr 64. Of the 8, they all show audio, but only 2 of them - number 1 in the chain and number 4 in the chain allow us to hear the audio from the headphone jack. Any suggestions?
Can’t think of a quick suggestion for the audio issue but you can use some off the shelf
POE ethernet switches for the ME series.
https://support.allen-heath.com/hc/en-gb/articles/4403292650641-ME-Compatibility-with-third-party-switch
How are your powering them? I suspect the ME-U hub was powering them before, but now that it isn’t working, what are you using? I suspect that the power supplies aren’t adequate. Have your tried swapping the 1 and 4 power supply to other units? That would be a quick test to see if my theory is correct.
Brian,
Thanks. We were powering them with the power supplies that came with the ME-1’s. We tried switching power supplies, switching cat cables. We tried everything and could only get those two to work. We updated firmware to the latest. No clue! We are up and running again because we were able to purchase a new hub, but still scratching our heads. They work perfectly fine with the Dante card and the hub, but directly from the Ace card and power supplies, we could see audio signal input on the meters, but heard nothing, either from headphone jack or mono out!
Hi Rlauck
Do you have access to the ME-U web interface? Can you confirm that the “Source Clock Sync” has an orange tick next to it? If not, try going through your system, making sure that all clocking settings are correct.
  • Jeff, A&H
Jeff,
Thanks. We had to return our Me-U Hub because we were unable to connect with it. We were attempting to run the Me’s from the Ace Card in port-B. Only 2 of the me’s would output audio. We ended up purchasing a new Me-U Hub and everything is operational now, but no clue why only 2 of 8 would output audio. We traded power cables, cat 6 cables - order of daisy chain. It was so bizarre.
Had the same issue… I had to set the Audio Clock to internal
Hi everyone, I’m have the same issue and have no idea. Mine is a little more odd as I have three ME units and two do not work going through the exact same Ethernet port one works completely fine.
All settings and firmware are updated and the same. Clock sync is ticked on MEU UI.
UPDATE: Master resetting fixed one of the units. The last one still doesn’t work ?
FIXED
Had to set the desk clock to INTERNAL - it was originally set to salve card. All ME units now work correctly. What a weird issue!
FYI we were using an GLD80 and the ME-U
