ME Processing
Hello everyone,
I just received an Avantis and I’m setting it up. We are using ME-1s for our IEM mixers.
In the past with Avioms and other mixers I have used aux outputs to feed the Avioms. And on digital mixers aux sends typically have EQ and Compression. My question is, do ME sends have the same options?
I know that I can select the send point to be preEQ or post delay, but what if I wanted it to be preEQ but then apply EQ and compression to the send independently of what I am doing for FOH. In the past I have EQ’d a kick drum for example and it sounds great in the house but the drummer complains in the ears it is too thin. So I can grab some IEMs and listen to the kick send and make adjustments specifically for IEMs that doesn’t change my FOH sound.
Is this possible with the ME-1 system?
Well [I’m using SQ], I’ll just go ahead and doubles up the channels [Kick and iKick for example - Kick will go to FOH and iKick will go to ME; now you can always apply different parameters]
Yes I suppose that would indeed work. Hopefully this is something they can add. Seems an awful waste of resources to do it that way. But yes that will work, thanks.
