Meter. problem when customizing User.
The ability to display meters on the screen in Avantis has a page that can be customized by the user.
It does not function properly when operating with v1.30 or the latest v1.31.
Symptom 1.
When “Add/Remove” any meter, if you put two meters vertically in a row, one different meter is not visible in the screen to set and cannot be removed.
When I press “Apply” and exit from the settings, the meter is displayed with two vertical rows of meters.
Symptom 2.
When CH1 to CH3 are placed in a row of meters in the Add mode, if you switch to the Remove mode and try to place a new meter with the same CH already placed (by mistake), a ghost of the same CH will appear on the screen, and the ghost cannot be operated.
I would like to hear from other users to determine if this is a problem specific to my console.
I just purchased a new Avantis last week. When setting up custom meters I also have the same symptoms.
