Hello,
I use iPad Pro 9.7 and SongBook +. What is the possibility of controlling QU-SB using MIDI commands from the tablet?
For example, controlling the effect and turning off/on effects…
Hello,
I do that using SetListMaker on an iPad and a QuPac, so I don’t see why you couldn’t also… assuming SongBook+ supports sending MIDI commands.
I run Qu-Pad on one iPad which connects to the QuPac via Wi-Fi. On a second iPad, I run SetListMaker which is hardwired into the QuPac’s USB port via an Apple Camera Connection Kit. As I change songs in SetListMaker, MIDI commands are sent to change various effects settings. When I run lights, SetListMaker also sends MIDI commands to change scenes on a song by song basis.
I have run both apps on the same iPad simultaneously, but switching between the apps (and often having to log back into QuPad) was often too slow for my needs.
