I have just got my idr48, t112 surface and mmo card (for my alesis 24 track). Everything works fine except I can’t get midi tunnelling to work. The surface transmits messages to the out port of the rack but I can’t get external devices to use the in/out ports as described in iLive MIDI Protocol - Firmware V1.8.
On the firmware note, the surface was shipped with 1.82 but the rack was shipped with a 1.81 sticker over the ACE port. As I’ve said everything seems to be working fine so I haven’t altered the firmware yet.
I’ve tried 2 different ethernet drums 80m and 100m. Any ideas?
You need to have the same version of firmware on the surface and the Rack or you will run into problems.
112T/IDR48/IDR16
Hi Pealsound
It is best practice to have all units running the same firmware version whenever possible.
This should not be a cabling issue if the iLive connects and works correctly, and you said that you can get MIDI out of the mixrack and surface OUT ports correct?
Can you try a MIDI learn function using a DAW application e.g. Ableton live just to see if you can get that working?
what are you trying to control exactly?
Regards
Sam A&H
Problem is solved. I updated the firmware on the mix rack (had to use the network connection), but this wasn’t the issue. It seems that if you have selected midi channel 1 in utilities/midi, then it “locks out” any thru traffic on that channel. Selecting midi channel 11 at random, I discovered everything I’m using (on midi channels 1&2) was flowing through fine. I suppose this makes sense because the console must have it’s own channel, or else any midi data which happens to be passing thru would interfere with console operation.
IDR48 - T112 - MMO card
