Miking and EQing a double upright bass on live stage
An AT PRO35 “condensor” should smoke the sound quality of the Shure dynamic mic. Live or studio.
Dan…
I have used both, as a player, as a live sound engineer and as a recordist producing CD’s from live performance. As stated above, I also have the option to choose from a host of other mics. In my personal mic locker I have well over 100 different mics. I will use whatever makes the most sense GIVEN THE CONTEXT. But the bottom line is this:
It’s not the hammer, it’s the carpenter.
The OP has access to Shure dynamics and has been advised that they can work and how to do it. He does not have the Pro-35. That’s the context. Should he gain access to more mics in future he’ll know where to look and what to try. For now, let’s just say that a 57 or 58 will be fine.
Yep, 57 & 58 are fine…it’s up to the carpenter.
Hi again guys
Well i done sound for the concert on Saturday with the double bass in it.
I tried wrapping a 57 in small hand towel and jammed it nice and tight under/between the tailpiece and body as suggested. Initially it sounded good, better than the 58 i had pointing at body to left of f hole. But then we got rattely sound when he plucked the top two strings. I tried jamming towel in a bit tighter but still got that sound but only from two of the strings. I was going to experiment a bit more with different positions and with a 58 instead of 57 (as i thought it might be the loose head that the 57 has when touched that caused the rattling sound??) but he didn’t want that as practice was about to start so we just went back to the 58 pointing near f hole…
Hi again guys Well i done sound for the concert on Saturday with the double bass in it. I tried wrapping a 57 in small hand towel and jammed it nice and tight under/between the tailpiece and body as suggested. Initially it sounded good, better than the 58 i had pointing at body to left of f hole. But then we got rattely sound when he plucked the top two strings. I tried jamming towel in a bit tighter but still got that sound but only from two of the strings. I was going to experiment a bit more with different positions and with a 58 instead of 57 (as i thought it might be the loose head that the 57 has when touched that caused the rattling sound??) but he didn’t want that as practice was about to start so we just went back to the 58 pointing near f hole…
Foam block for cardioid dynamic handheld type mics, flannel cloth to wrap the foam (foam chemicals can react with instrument lacquer, so you must cover it) and Velcro cinch-straps to secure the whole shebang under the tailpiece.
It could very well have been the ring on the 57 that was rattling. I prefer to use a 58 as the ball makes for a better " wedge". But I repeated my method above for future reference. Also, a small hand towel probably was not nearly enough padding when using only a towel. You need a good chunk of thick terry-cloth bath towel, not something with material like a T-shirt…although I’ve used several T-shirts in a pinch.
The important point is that you learned how good it can sound. Swap in a 58 and you should be good to go.
Yes Dick i do think it was the ring on the 57 that caused the rattling. Btw i used a standard thickness hand towel. It was definitely thick enough,a bigger towel wouldn’t have fit under tailpiece without risk of straining and damaging it. Yes i had a feeling the 58 wouldn’t have rattled,but the bass guy was impatient,his loss. If he hadn’t have turned up nearly 1.5 hours later than other guys for the final rehearsal just before the gig i would have had plenty of time to experiment. …!!!
See if you can find a foam insert the mics come in out of the box like I described earlier. that, some soft cloth and a Velcro strap will keep it in place with no rattles.
Good luck.
