Hi fellas,
Is there any jumper or switch or function necessary to switch the DR ports on the MMO card to output Hearbus?
thanks
Gil
Gil Parente
Design & Integration
Entertainment Arts, Inc.
Hi fellas,
thanks
Gil
Gil Parente
Hi Gil
The sockets will work with HearBus without changing any option or switch. Please note that the sockets are for connection to a HearBus Hub only (not mixer of extender).
Cheers
Hello-
I am having trouble I am unable to get connection with my hear bus. Is there some trick to make it work for the hear bus? I just received the IDR unit with the multi card installed. I set it up and plugged it in and all I get is red lights on both my hear bus hubs. I know the IDR firmware is up to date, however is there a separate firmware update for the card? Please help! My clock is ticking!
Michael
Hi Michael,
I had the same problem a few month ago. I’ve changed the CAT5-Cables to connect the Hearbus-Hub with the IDR-Unit. I think the problem is the shield of the CAT5-Cable. (UTP / S-UTP). Please try it out. I use a short patch (1,5m) from the IDR to the Hearbus-Hub.
Cheers
Florian
Soundwork Engineering
Germany
Hi
The hear buss system wont work on a cat5 cable longer then 30ft
T112/IDR-48 User
