Hi - we play in venues where we sometimes use our own FOH kit but we are also asked to put our mix into the venues system so they can pipe it through the venue at a volume level they control…
What’s the most efficient way of setting up a couple of extra outputs (I have two spare) that mirror the L/R main mix but have an independent level control to the mix I am putting into my kit?
Basically I don’t want to do a separate mix but I do want to be able to give them more or less as needed…
Sorry if this is a stupid question but I’m pretty new to digital desks and possibilities.
Oh it is an IDR16 with iPad and MacBook editor running.
Because of this I recommend to use matrix for PA instead of direct LR outputs, in case you have to give signal to recording or broadcast you can use another matrix and no PA equalization will be in that feed.
I always tend to feed from Matrices not L&R gets you over the same old same old, the videots turn up 5 minutes before the gig and do the can we have a feed etc. etc. so just program a couple of stereo and a couple of mono matrices and you are one step ahead.
