Mix Bus with DAW
I am trying to create multiple mix sends to go from QU 24 to a headphone Amp while using the desk as a DAW controller/interface in a studio environment but can’t seem to find a way to route through to the mix faders.
Does anyone have a workaround or solution to this please?
I have sorted it.
RTFM, simple
Its not simple actually and its not in the user guide. The section on output patch set up is very vague and basic. As it turns out, using the patch bay you can only route to stereo channel faders 2 and 3 to use as control for 2 stereo mixes unless you sacrifice some of the 24 input channels. Its always better to be helpful on these forums.
I’m a brand newbie to Allen & Heath, and have had the same problem. Would you mind telling me how you routed your headphone mix?
Or even which section of the manual was relevant…
