Mix Ext In tap-in point
I’d like to be able to select at what point the Mix external input taps into the output, for example whether it is pre or post the master fader.
In addition I think it would make sense to choose different Mix external ins for each PAFL bus and be able to patch and trim them separately rather than one global setting for the two different PAFL busses… They’d be being used for different purposes so out would make sense to have seperate Mix-Ext in settings.
