Recently I am having an issue with the PAFL, where when I press it, the LR mix is overriden by this. So if I want to hear a specific channel in my headphones I will hear it on my headphones but also in the main mix, even if this channel is on mute. I have updated the firmware to the latest version after I found this. So I don’t think it has to do with firmware. Either i am overlooking something within the PAFL setup menu, in which i believe i tried everything, or there is something else going on. Does anyone have an idea what it could be?
Have you patched Listen or PAFL to the output sockets you thought to use as main LR out?
Check the I/O - Outputs - Monitor Out view and also which output sockets main is going to.
Like SteffenR suggests also check the master role (“Monitor” = Main select LED is red, main fader controls listen bus).
If you want to keep it like that put the “real” main fader on a layer.
