Hi All,
We are trying to set up a means for our band to mix monitors with a limited number of iPads. We have decided to set up a couple iPads with MixPad installed and created a user with reduced permissions so that they can mix their monitors without the risk of changing anything else. My one question is this: is it possible to give that user permissions to mix the aux mixes but not the mains? We want to avoid a situation where a musician inadvertently mixes the room instead of their ears.
Thanks.
the OneMix app is made exactly for this
We do use OneMix for monitors. However, we are not able to provide a sufficient number of iPads for every musician to have their own, so we need the ability to mix multiple monitors on one iPad (we have 9 IEM mixes and 3 iPads). Since OneMix locks itself to a particular mix, we are using MixPad for this purpose. Thus we are looking for a way for the bad to use MixPad without messing with the LR mix.
ok I tried it and it works different than the SQ4You or the QU-you app
on both it is easy to do what you need
but you can build a Custom Control setup to provide one App with more than one mix available…
but it’s a bit work…
