Mixes/output channel processing - ability to swap insert point
Hey folks!
So I’ve come across a minor irritation: I understand you get one insert point on output channels/mixes, but I would like the ability to pick whether it happens before peq/geq/comp or after. For instance - I have program material I’m sending out a mix bus that hits PEQ/Comp (Parallel Fairchild,) and I would like to also add a brickwall limiter inline before the analogue outputs it feeds. I could easily do this with our in-house DSP rack, but I need it to be in that last position before delay. I suppose the workaround currently is to not use any of the internal compression and do all the comp/eq processing in DSP rack, but that seems silly.
