mixing an aviom system from the board
Hi I’m having trouble getting the aviom system dialed in. we have the ilive t112 board. Foot some reason in the in-ear headsets the bass and drums ar very week. I would say maybe ok too the drums being a mic’d item but the bass is direct line? Is there any way to master mix the volume to the aviom without affecting the mix in the mains? Obviously each pod can be adjusted but im cranking the bass and drums on the pods to even hear them? Thanks
Brandon Waddell
Hi Brandon,
I’ve done a few shows using the Aviom system fed from an MMO card in the Mixrack.
Firstly, what are you using to interface between the iLive and Aviom?
If your using the aviom analog interface you need to make sure input levels to the unit are set right.
The next thing i would look at it where to use as send points to the aviom as there are several ways of getting inputs to the aviom, i.e Mix Rack Inputs, Channel Direct Outs, Mixes and so on.
I would set in such a way where the Kick, Snare, Hats and Bass are fed via Direct outs into the aviom then some mono/stereo auxes for the rest of the aviom feeds. again, its all down to how much control your band needs.
I hope this is of some help to you.
Matt
Matt Gunter
1 iLive 144, 2 T112, 3 R72, 1 GLD80, 3 iDR64, 2 iDR48, 1 iDR32, 2 iDR1616, 2 M-Dante, Mac Book Pro, iPad, Logic Pro, Reaper
