Mixing problem
Ciao,
I connect qu16 to my Mac book pro for using in logic x with LAN.
I had some project with many tracks (35/40)the last recordet with qu16. The audio is ok but I had some problem when I try to mix, often all the track become mute and one in solo the other problem is the pan, randome in many tracks the pan continue to change
Hi Macky,
I’ve seen this before and it sounds like you missed the last few steps of the ‘DAW Control Setup Notes’ instructions for Logic. These steps prevent the raw MIDI stream from the mixer to interfere with the Mackie Control messages. Make sure you connect all incoming MIDI ports to the Monitor object in Window / Environment.
Hope this helps.
Yesterday I try again I made again the connection, the panpot seem ok but i I click on the mac on a strip this strip became in mute and solo.
