Sorry for the inflammatory title for this post, but I just need to vent my frustration with MixPad in the hope that somehow someone will either tell me what I’m doing wrong or at least agree that it is an app that still needs a lot of work.
The key problem with this app is that it stops working with no warning, no error message, and at any time during a given show. By not working I mean it doesn’t respond to fader adjustments, or fails to respond to channel or mix changes or EQ adjustments. For example, I’m near the stage, and someone asks for a monitor adjustment. I try making the adjustment, and nothing happens. The artist stares at me and says nothing is changing. I then either stop and then restart the app or run to the MacBook (which is wired to the MixRack) and use the Editor. I average about five app restarts per hour. This is simply unacceptable, especially given the fact that the app costs $100.
Now I am prepared to get flamed from people who have no issues whatsoever with MixPad, as there probably are many out in the world. So, to give you an idea of what I’ve tried to do get MixPad to work properly, here is a fairly comprehensive list.
I have:
Researched the entire iLive forum for every topic relating to MixPad.
Consulted the iLive Support web site and iLive documentation.
Bought six different routers, including two D-Link DIR 815 routers. (The others being Airport Extreme, Airport Express, a Belkin, and a Cisco/Linksys.)
Tried turning on/off multicast on the MixRack.
Tried turning on/off multicast on the routers, if possible.
Tried turning on/off multicast on MixPad.
Followed the instructions of the A&H video showing how to configure the DIR 815.
Tried turning on/off encryption, DHCP server, DHCP reservations, MAC addressing.
Tried 5 GHz configuration only.
Tried 5 GHz 802.11a only.
Tried turning off 2.4 GHz on dual routers.
Tried various combinations of 802.11 configurations.
Tried turning off SSID broadcast.
Tried using static IP addresses only for the MacBook and iPads, making sure they are all unique.
Tried taking off the cover of the iPad, just in case it was interfering with the WiFi antenna.
My MacBook running the Editor connected to the MixRack via CAT 5E and the iPad, of course, connected wirelessly via the router. The MixRack IP address is 192.168.1.1. The router address is 192.168.1.254. The MacBook 192.168.1.100. The iPad 192.168.1.101 (unless DHCP sets them to something different). Subnet mask for everything is 255.255.255.0. MixRack, MacBook, and iPad are the only components.
None, none of these measures makes any difference. Sooner or later MixPad stops working with no notice. I have MixPad installed on two iPad 2s, and the behavior is the same, so it’s probably not an iPad problem.
I think I done a reasonable amount of research and experimenting on this issue and have gone overboard in buying routers. I simply can’t imagine that I’ve overlooked something obvious.
I love what the iLive MixRack can do. It sounds great and has a wealth of features that aren’t available in the PreSonus and Yamaha boards I work with, though the iPad apps for those boards give me no problems at all. For my iLive purchase I deliberately chose to do without a control surface, assuming that MixPad and the Editor would be sufficient. However, I am handicapped, not enabled by MixRack. My only hope is that it will, sooner or later, be updated in a way that works for me.
Flame suit is on in case it’s an operator problem.
