Hello together,
how can i control a slave rack with the mixpad app? The only rack i can control is the masterrack, the slave rack wont appear!?
Jan
Hello together,
Jan
JAN,
So far as per the mix pad page, The app does not support dual racks. The slave channles would not be recognized by the mix pad app.
JEFF FLOWERS
VOLCANO ADUIO PRODUCTS
SHEPHERDSVILLE KY-USA
To me, it would make since to have a feature in both the Tweak app and MixPad app to call up the surface (much like the Editor) rather than just controlling the mixracks. If it would control the surface instead, then it would essentially be a “control surface for the control surface” and you could control any channels assigned to the surface, including slave rack channels.
quote:
Originally posted by ClintageTo me, it would make since to have a feature in both the Tweak app and MixPad app to call up the surface (much like the Editor) rather than just controlling the mixracks. If it would control the surface instead, then it would essentially be a “control surface for the control surface” and you could control any channels assigned to the surface, including slave rack channels.
Not a good idea, in case of no surface you can’t control anything…
That’s why it is like it is…
SRV-AVB
R-72, iDR-16, xDR-16
