Thanks for the info. if i touch the chaneel, nothing changes. If i double tap, it highlights and the ‘blue light’ switches on. But the channel, pre amp etc. stays on channel 1??
You need to TAP once to select the channel in the area between the Mute switch and the Fader or ON button - I suspect you are touching (and holding) on the channel which wont change the selection.
Cheers
Richard Howey
Audio Dynamite Ltd
