When a bluetooth device is connected to my CQ18T I get constant connection error messages pop up on my iPad. Connect is always restored but means lose the ability to control anything until the message disappears.
Not sure if this is relevant to your issue but the manual mentions that if you’re using BT you should configure the built-in wifi to use 5G instead of 2.4 because BT also runs on the 2.4 band and can interfere with the built in wifi.
Will give that a try. Thanks
