Mixpad Fails to connect to SQ5
I’m using a Netgear Nighthawk M2 directly connected to my SQ5
My Ipad Pro and the SQ5 both receive an IP-adress through DHCP (Ipad 192.168.1.22 – SQ5 192.168.1.21)
When I open the SQ mixpad, the software shows the SQ5, but whenever I hit the ‘connect’ button, after a few seconds the SQ mixpad shows: ” Failed to connect, Unit discovery timed out’
Firmware SQ5: 1.54 r3979
Firmware SQ mixpad: 1.5
Does anyone know what I’m doing wrong and what I can do to make it work?
Thanks for the effort and I look forward to your reaction.
Kind Regards
Try setting a static IP on the mixer.
You’ll need to configure the router so the DHCP handout range does not conflict
with the static IP on the mixer.
Say the mixer is set to 192.168.1.10 the DHCP range on the router could start at 192.169.1.100.
tried mine it works what mike suggested!
