Hello all,
I just setup the mixpad app to use with my ilive yesterday. I’m having a problem with changing the mixes. It appears that whenever I change an input parameter in one mix (e.g. level, pan) it changes its settings on all mixes. Even when I change a EQ setting on one input it changes it on all inputs. Does anyone know how to fix this issue?
Sounds like you are trying this in demo mode, is that correct? You need to be connected wirelessly to the iLive system to load actual settings when you eg. change the mix or selected channel.
iDR 48, T112, iPad3 +4 + TL WDR4300, Dante
Ok. However, even when connected to the t112 when I changed the input routing to one efx send it changed it on all of the efx sends. Can you explain why that happened?
