Mixpad LR Master Layer blocking
Hello
I am wondering if it is somehow possible to disable the Master Layer for different Users in the Mixpad App.
In a Festival Situation it would be very healthy if the monitor dude with the tablet in a stressful environment couldn´t change any Master Layer Settings by hazard…
It´s easy to Block single or several AUX Layers but I haven´t found yet the opportunity to block the Master Layer…
Thanks for Help!
The SQ Mixpad app is designed to be a fully featured app. It is going to allow users access to the main L/R mix
The SQ4You app is designed to be used to control individual aux monitor sends. As such, it only allows access to auxes and not the Main L/R mix.
It sounds like you need to use the SQ4You app for your other users.
Hi Brian
Yes! The SQ4You App is very very cool for musicians… works brilliant! Love it!
But to manage 6 different Mixes on a stage it seems complicated for a monitor engineer with a tablet to constantly assign the concerning channel to one of the 4 encoders…
Maybe you should check out the awesome 3rd party app “Mixing Station”.
It could help you achieve what you need, because you can create custom layouts for almost any situation.
Yeah… thank you!
A custom layout would do it even without any blocking…
that’s a cool workaround :slight_smile:
