MixPad "Routing"Screen
I was just trying to set up my SQ from home and discovered there is no “Routing” option. Is this coming or not intended to be added ever? Does anyone else want this added?
+1
There s no routing screen but you can assign/unassign every channels to every mix directly from layers. The ON key on each channel appears with the long fader screen mode.
Same thing for pan . But it would be nice to see them permanently like the qu’s indeed
Sorry i can’t edit my post, but just after posting i thought it s probably a choice from a&h to avoid assignement errors while mixing…
@Fab Thanks, but I am primarily looking to set up some matrices.
My understanding of routing to matrices is that you select the mix layer on the app and then highlight the matrix you want to route to. Then if you look to the right of the preamp section you should see a small grey arrow, press this and you will be taken to the routing page. Alternatively if you highlight any of the other outputs and press the same arrow you will see each matrix it can be routed to (you have the following controls pre/post, on/off and level)
That’s right
They need to make a MixPad App reference guide. Thanks guys
Hi @spleeding,
There’s an SQ-MixPad help document available in the app from either the ‘Choose Unit’ screen (touch/click the ‘?’), or when in the app from the main session menu drop down.
[this is an accompaniment to the SQ reference guide and so it deals with MixPad specific features only, however, this does include a screen navigation tree and points out the ‘second screen’ arrow that gets you to the routing screen]
Hope this helps!
Cheers,
The older I get, the dumber I feel. I’m not sure how I missed that. Thanks. Maybe this should get moved to general discussions.
Hi @spleeding,
Definitely don’t feel dumb - it’s on us that it wasn’t more obvious!
We may take a look at the positioning of the routing screen again in the future.
