MixPad update
It would be nice to have in mixpad reverb decay settings!!
Pls!
Mixpad should get complete FX-Rack access to use it as a real remote!
Today I have to use a PC in addition accessed by Jump-App and TCP/IP-App for special features.
Günter Eisbach
dL-Recording
Darmstadt / Germany
If it were a “real” remote you could select channels to PAFL as well. I find it a little frustrating that I have to rely on the guy @ FOH to PFl the monitor to my IEM when I’m on stage working on IEM’s with the vocalists.
I’d love to be able to walk up the the LV and solo his mix in my ears as I’m adjusting it without the FOH guy having to keep an eye on me to see which person I’m mixing for at the moment.
Well… you can, actually- just use one pre fade aux, send all inputs to it and then just assing necessary channels to it. Not the straight way, but does the job.
ddff
quote:
ddff
If he wants to assign mixes, it’ll be a matrix he has to use I suppose?
Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
There is a work around. Create a Matrix and set the output of the matrix to feed the engineer’s IEM. Assign all the artist auxes to that matrix. To hear an individual artist aux just pull down the faders for all the other ones in that matrix. Its not an elegant solution, and it doesn’t help at all with PFL for inputs. It is a workaround though for PFL on an aux.
-d
Mixes already have PAFL, he needed to be able to monitor inputs if I got it right.
ddff
ddff
nope… “I’d love to be able to walk up the the LV and solo his mix
Wouter
I was concentrated to: “If it were a “real” remote you could select channels to PAFL as well”
Soloing the mix isn’t a problem quite a long time now.
ddff
Mikey -
Get a 1/8"-3.4 mm headphone splitter, plug in your earbuds and listen. You’ll be onstage and get stage ambience with the exact mix, although possibly being filtered through different earbuds…
PAFL not needed.
Tim Tyler
Detonator Sound
Richmond, Va USA
T112/48 R72/32 laptop iPad Dir-815 Dante
You can pfl any of the mixes just click on the GEQ tab
And you’ll see the pfl button. Just not able to pfl input channels.
[:smiley: ]
