Hello,
If I have one T112 and two iDR-32 with M-ACE-A modules installed, then can I get 64 inputs at the same time and control by the T112?
Hello,
No… The T112 surface only has 1 ACE connection.
Hi All
In the current firmware V1.54 we do not support dual Mix Rack functionality.
Soon we will be releasing V1.6 firmware this release will enable dual Mix Rack functionality so it is possible to linkup 2 Mix Racks together via the Port B (ACE, EtherSound or MADI) link which will enable a maximum of 128 input channels.
More information about Dual Mix Rack setup will be available with the release of V1.6.
Regards
Sam A&H
hello
when shall the 1.6 software be ready ?
Would it have also the functionality of running two surfaces (FOH & mon) with one MixRack ?
best regards
Przemko
In my opinion two surfaces with one mixrack is not possible, since the processing is in the mixrack not the surface.
The only thing possible would be to take 2 surfaces along with two mixracks and take the inputs of one mixrack and have processing seperatly.
But its not implentet yet - maybe also in 1.6.
Albin,
I think that it is possible. if you have an IDR32/48 you could split 64 process channels in 2 sets of 32. you assign the inputs 1-32 to both sets. now you have separate processing for FOH and for MON. in fact the surface is just a controller over utp so there is no reason to not be able to make surfe 1 control the first 32 processing channels and surface2 the second 32 without interference between the both.You can do this already with surface and laptop. The only thing left to do is to make the PFL on the rack act as the PFL for the second surface ( monitor).
kind regards
Lieven
T112/IDR48
Disclaimer: I disclaim everything. The contents of this message might be totally inaccurate, inappropriate, misguided, or otherwise perverse - except for my name (hopefully I got that right).
Yes of course - in THAT way it is possible - but not in the case usually meant.
You have to share processing power and are not fully seperated - so thats not an option for bigger acts.
Hi All
Only 1 surface will be supported in V1.6 firmware. Though you can use iLive editor for further control of the system you can connect multiple editor sessions to the mixrack
Hope this helps
Sam A&H
