MixRack Startup Scene - not working?
Has anyone tried using the 1.9 feature “MixRack Startup Scene”.
I’m running 1.95 and haven’t been able to get the MixRack Startup Scene to work. The chosen scene shows in the scene list with a power icon next to it. But shutdown and restart of the MixRack doesn’t honour the start-up scene - the MixRack starts up in the state it was when shut down.
Tried saving the show but still no difference.
Have I missed a step or misunderstood how it’s meant to work?
Thanks, Darryl.
I just did a couple of tests and things worked for me the way I expected.
However, there is one big limitation to the power on scene that is rooted in the way scenes work on dLive. Surface parameters are not stored in the Mix Rack, so when the Mix Rack powers on and recalls the power on scene, it can only restore the parts of the power on scene that pertain to itself. That means that things like strip layout, soft key assignment, etc. will not be recalled at power up, even if they are part of the power on scene.
Thanks for the explanation @msteel. That makes sense.
Following another test I now see that it is actually working that way.
Much appreciated!
