Monitor mixing
How many pre fader, mono, monitor mixes can I do with the SQ7, using the digital snake, at 96 kHz?
12, I believe. Either mono or stereo. If you only intend to connect to monitors via stage-box, then your number of mixes is of course limited to the number of outputs on the stage-box
If you add ME boxes, then you can expand the number of monitor mixes to practically any number you want. These are 48KHz, but do not impact the rest of the 96kHz operation.
