I Have a CQ18T. I got it for a music group. I get everything set up, mains, side fills, vocal monitor. the thing that gets me is that I can’t make the side fills to besides the music make it vocal monitor also. because I don’t know how to get to the monitor part in the menu. because it will not show sends in the output part of the menu. can you please help?
Let me guess:
You have set up a Post Fader Output mix as a side-fill so that you can hear roughly the same thing on stage as what comes out of the MainLR.
And you have set up a Pre Fader Output mix as a vocal monitor.
Now you want to mix this monitor mix into the side-fill as well. (?)
However, this is not possible, because all 6 Output mixes and the MainLR are independent of one another.
That said, nothing stops you from, for example, increasing the vocal level in the side-fill enough so that it also works like a vocal monitor.
