Mono/c bus
Hi!
I’m very used to using the mono bus. I was annoyed when I found out about the lack of this feature. In my opinion it would be possible to add a mono bus as well as groups or auks, but that would have been the ability to send AUX and groups
Please consider my proposal
Hi @ilya20008,
Depending on what you are wanting to use this for, you could utilise a mono matrix, which then gives you extra processing including GEQ, PEQ and Compression.
This could either be fed solely from the LR mix, or by any combination of mix busses.
Unfortunately, it is not possible to send a signal from the input channel to the matrix bus, and it is wasteful to use an additional AUX bus
