Mono LR out QU-PAC?
Hello
Is it possible to mix in mono? How can I select the LR out to be mono? I can see that if I am using the ar2412 I can patch two outputs as L+R. but what about if I am not using the ar2412?
Thank you
Alt Out: select “L+R” from Output Patch menu.
i see that but I want to use the main LR fader
Alt Out follows the Mains fader. Set the Alt Out pot to the arrow/zero/unity marker.
Try reading the manual while at the board.
I see. Thank you
Pan all channels to Center.
And since that’s the default setting it’s eezy-peezy.
The reason I feed my PA summed L/R from the Alt Out is so I can solo two or more channels and do compimentary EQ’ing panned in the cans without the panning messing with the live sound.
