Mono out
@DFT
we only have mono out at church
if you do not feed stereo in, you will get mono out
I believe they set it up without any stereo pairs using all ins as monos; except for one mix as we ran out of mono mixes
but they only used one out from the mix pair which was mono as we do not put stereo in anywhere
if they club has no stereo signals you should have no problem
22fuzzi: Duh! Wrong forum can be a problem. Thanks!
volunteer: Mono input not easy with recorded music playback. Thanks!
@DFT
recorded music – put in DAW , convert to mono , then record that onto media to use to play back
Matrix outputs can be configured as Mono. Simply send your L+R mix Post fader to the Mono matrix and you should be all set.
This same question was just posted on the QU forum a couple days ago.
QU mono out link here
