I as a musical theatre mixer am frequently running out of DCA’s.
On any given show I am using all 24. Granted some are being used with their level locked to 0db as a quick spill and that could MAAAYBE be covered as a Layer assigment but but all the same I could really do with 32 or more.
My standard template is a compromise to fit all that I need, but I often have issue where say i want to drag drums down vs perc or add in another group or Mic Mix, I really just need more DCA’s!
Eg.
DCA 01 Control Group Mic Mix
DCA 02 Control Group Mic Mix
DCA 03 Control Group Mic Mix
DCA 04 Control Group Mic Mix
DCA 05 Control Group Mic Mix
DCA 06 Control Group Mic Mix
DCA 07 Control Group Mic Mix
DCA 08 Control Group Mic Mix
DCA 09 Band Mix
DCA 10 QLAB/Playback
DCA 11 Vox Fx Sends
DCA 12 Main Outputs
DCA 13 Drum/Perc
DCA 14 Bass
DCA 15 Keys
DCA 16 Guitars
DCA 17 Strings
DCA 18 Reeds
DCA 19 Brass
DCA 20 Groups Spill
DCA 21 Aux + Matrix Spill
DCA 22 Fx Send/Return Spill
DCA 23 All Inputs Spill
DCA 24 Pop Group Spill
Also, gimme a metering sum on them or something, anything pleeeeeease!
I also would like to see DCA metering but it has no audio, if there are multiple sources assigned, which audio would you display? DCA does no summing of audio. but it would be nice if i link a dca to just one group or channel to see that audio.
For me, the loudest member would be fine… I just need a sense for how much DCA (in non-degenerate situations where nothing is double-patched and phase flipped) is contributing to what I’m hearing.
Yep, in Musical Theatre, I throw up my control group DCA’s I might be driving 36/48 RF Mics, If one of them has a broken cable/RF issues or is talking offstage instead of singing as is common at our level, I need to see a meter right in front of me showing that, I don’t care if its not super sample accurate, just anything more than nothing, its only ~4bits of resolution anyhow.
For example, it could display:
The highest post-fader signal level among assigned channels.
An aggregate level calculated from the assigned channels.
A peak/overload indication when any assigned channel exceeds a threshold.
That extra split second before having to go hunting through spilling makes a huge difference in our game.
Please add an option to display level meters for DCAs, based on the summed energy of their assigned channels. These meters would be extremely helpful for quickly identifying which DCA contains the instruments currently playing.
I understand that a DCA is not an audio summing bus, so this would not represent an actual group output level or account for phase relationships between the assigned signals. The purpose is to provide a useful visual indication of activity and level across those channels.
I discussed this with an Allen & Heath employee, who explained that displaying values that are not directly measured goes against your design philosophy. I understand that concern, but DCA meters are available on other manufacturers’ consoles, and users familiar with them understand their purpose and limitations.
Please make this available as an option in Setup, so users can choose whether to display DCA meters.
