Hi, It would be nice to be able to use the mix outs as mono instead of stereo. We never use stereo wedge on stage but with a band of more than 4 we are stuck or use a merger to run the monitors in mono. Please implement the option in a next update.
If you just use the left output of the upper mixes then you get 7
If you have one of the larger boards then 1.8 will give you more possible mixes (sacrificing groups)
I agree with mervaka - a width control would be welcome. I’m not sure how tough that would be to implement, but my guess is that it would just be a software button add that could be controlled by the encoder knob.
For mono sources, just keep the pan control in the center, and both channels of a stereo mix output will get the same signal. For stereo inputs, you may need to use a simple Y joiner to send both channels of the mix output to a mono source.
We run our system in mono, and for stereo sources we send the two channels to separate inputs on the mixer. This is primarily because we use a lot of split-track sources, and it’s easier for the operator to use two faders to mute the un-needed channel. Thus, we only need to connect to one channel of the mix outputs. If you choose to do it that way, and your mains run in stereo, you will have to pan the two inputs right and left.
