I use a blend of two mics on guitar cab (57/421) and want to just send that as a “mult” to a single channel in my DAW via the Qu-24 as my interface.
I could probably buss to 25/26, but don’t really want to burn a stereo buss for a mono track.
Could I get away with selecting the same channel output to USB for Qu channels 19 and 20? i.e. go into settings on the Qu and choose “USB 19” for both 19 and 20?
To combine/mix two (or more) channels a mix is required, either in the Qu or your DAW. Though of course if you are mixing them in the DAW, you’re still sending two channels from the mixer which is something you wanted to avoid.
It is not possible to send two channels/sources to one output without mixing them, and in case it helps, I personally imagine the USB channels as empty ‘slots’ which can each be assigned one thing.
That thing could be an insert send, a direct out or a mix, but the important part is that you are assigning a source to the USB channel rather than a USB channel to the source.
not possible - select the same USB channel for two sources is possible - select the same source for two USB channels
