Multi-channel library
Would love to see a way of saving a library of multiple channels at once… instead of having to recall a library for each channel at a time, be able to save and recall a block of 12 channels… IE drum kit… or 2 channels of Bass/keyboard settings, or 48 channels of stage inputs…
Further to this being able to scope what parameters are recalled from a library… recall filtering I guess.
Perhaps a scene would work better for you?
Sure, happy to use a scene to yield the same result…
At the moment a preamp value seems locked to a socket and not recallable from a channel via a scene though.
At least a library setting can be used to push a preamp value onto a socket, so it seems a little closer to possibility when considering the amount of development required.
