I have 2- C3500 console 1- CDM64, 1-CDM32, 1-64x64 Dante card. Trying to do a FOH and MON setup splitting channels.
Is there a this setup can be done. Or a gigaAce card will be needed?? GigaAce card is backed ordered 8-12 weeks
You will need either a Gigaace card or a second Dante card (or two Waves or Madi cards). Gigaace is probably the preferrable option as it is cheaper, faster, and a full 128x128.
TBH, with two mixracks, it is only a split, not multiple surface.
Multiple surface means up to four surfaces with one mixrack.
Every surface needs to connect via GigaACE.
To do the split, you need a card in both systems that enables the audio split. Both cards need to use compatible protocols.
@ejayala808 you require a second Dante card for the split.
Brian,
I do have a waves card, would running a waves and Dante card work?
I do have 2 surfaces, both C3500.
Also a waves card and a Dante would running a waves and Dante work ?
No. They are not compatible at the moment.
