As the manual is very vage on some of the multi surface ins and outs I am trying to shed some leght on this.
This is for a multi room installation with a DM 48 and a giga ace card installed and 2 C Class consoles.
The manual talks about “primary” and “secondary” surfaces without giving any clue, what the differences are. At least there seems to a difference in how the surfaces have to be connected to the mixrack and in what order they have to be switched on.
My findings so far:
- primary console must be connected to internal gigaAce and switched on
- only then a secondary console can be connected to the gigaAce card (frontpanel network bridge switch to “on”) and sees the mixrack
questions:
- for what situations the frontpanel network switch on gigaAce cards has to set to “off”?
- is there a way to connect a surface to the gigaAce card without having the switch on the surface connected to the internal gigaAce port? in my setup (firmware 1.7) this is a no-go. That surface won’t see the mixrack.
questions:
– for what situations the frontpanel network switch on gigaAce cards has to set to “off”?
if you need two separeted networks and using the GigaACE port only for splitting
– is there a way to connect a surface to the gigaAce card without having the switch on the surface connected to the internal gigaAce port? in my setup (firmware 1.7) this is a no-go. That surface won’t see the mixrack.
no, see above...
the switch affects only the control network
maybe something here gets lost in translation. If you talk of “networks” you a talking control networks?
Can you point me to a practical situation for this?
regards
nothing lost in translation…
audio and control network follow the same rules…
a separeted broadcast mix in a different room with it’s own mixrack (or a SQ, since the S-Link understands GigaACE)
any situation where you really need to separate the split from your main control network
this is not multi surface mode…
in multi surface mode you have multiple (4) surfaces (S, C, Director) in one shared network
Hi RS,
Just to confirm, did you download the ‘Understanding Multisurface’ document as well as the Firmware Reference Guide?
https://www.allen-heath.com/media/Understanding-Multi-Surface-ISS1.pdf
Ah, there it is…
Link to the reference guide is in the software download section. And no clue in there for additional info. Maybe a hint for the stupid ones like me?
thanks!
