Multiple PAFL at one time.
New to Allen and Heath Digital but ran a Soundcraft digital for over 2 year and one feature I really liked was the ability to “solo” multiple channels at one time to listen to all BGV’s at one time or a couple of guitars at one time…Please tell me there is an easy way to do this ON THE FLY without having to set up a group or anything like that???
Setup>Audio>PAFL Additive mode: On
PS, if you turn this on, it’s probably worth adding a PAFL clear function to one of the softkeys on the surface (Setup>Control>Softkeys Select a softtkey, Function:PAFL clear) so you don’t have to go hunting through layers to find that one channel\bus that’s still PAFLed.
PPS, if you’re wanting to listen to a whole lot of BVs together and have their levels and FOH panning in the cans (if applicable), Setup>Audio>PAFL Input AFL: On. Of course the downside to this is that the AFL setting applies to all your inputs, which means you can only PAFL inputs that have their LR fader up.
Cornelius THANK YOU SO MUCH!!! You have mine and our WL’s day! Thank you so much! This is just what I was looking for!
The GLD will also let you PAFL a DCA, even though DCAs dont actually contain any audio. I think it actually does an additive AFL “behind the scenes”.
Chris
