We had our 3 hour long concert recorded as 18 multi track files into a SanDisk Extreme USB3. When I try to copy the files to the computer, track#2 refuse to copy, the finder is saying it cannot read this file. It must be corrupted, all the other tracks are fine. So I tried to use windows disk scan as suggested before to restore this file, but the result is it become a very small file (16k or something). Since the normal restore method does not work, as an all software engineer band, we start to work on a lower level.
The disk format is FAT32, from this article (Paul's 8051 Code Library: Understanding the FAT32 Filesystem) we learnt how it index the file into sectors and cluster. The cluster index must be messed up on track2, that’s why normal tools cannot recover the correct content. So we wrote the following C++ program to print out the cluster chain of track 1 which is OK to find out the sequence. The result shows that only the first two clusters are not in the right order for track2. We recovered it successfully! And the advice for everyone is to format the disk before multi-track recording every time.
#include <iostream>
#include <fstream>
#include <cassert>
#include <cstdint>
#include <algorithm>
using namespace std;
class Fat32 {
private:
static const size_t header_size = 0x74fc * 512;
ifstream fin;
vector<char> buf;
size_t BPB_BytsPerSec;
size_t BPB_SecPerClus;
size_t BPB_RsvdSecCnt;
size_t BPB_NumFATs;
size_t BPB_FATSz32;
size_t bytes_per_cluster;
uint32_t *fat;
public:
Fat32() {
fin.open("/home/wcgbg/recovery/sdc1", ios::in | ios::binary);
assert(fin);
buf.resize(header_size);
fin.read(&buf[0], header_size);
assert(fin.gcount() == header_size);
BPB_BytsPerSec = (uint16_t &) buf[0x0b];
assert(BPB_BytsPerSec == 512);
BPB_SecPerClus = (uint8_t &) buf[0x0d];
bytes_per_cluster = BPB_BytsPerSec * BPB_SecPerClus;
BPB_RsvdSecCnt = (uint16_t &) buf[0x0e];
BPB_NumFATs = (uint8_t &) buf[0x10];
assert(BPB_NumFATs == 2);
BPB_FATSz32 = (uint32_t &) buf[0x24];
uint16_t signature = (uint16_t &) buf[0x1fe];
assert(signature == 0xaa55);
assert(
(BPB_RsvdSecCnt + (BPB_NumFATs * BPB_FATSz32)) * BPB_BytsPerSec
== header_size);
fat = (uint32_t *) &buf[BPB_RsvdSecCnt * BPB_BytsPerSec];
void read_file(const char *short_filename, uint32_t offset) {
cout << short_filename << endl;
fin.seekg(offset);
char dir_buf[32];
fin.read(dir_buf, 32);
assert(fin.gcount() == 32);
assert(equal(dir_buf, dir_buf + 11, short_filename));
uint32_t first_cluster_high = (uint16_t &) dir_buf[0x14];
uint32_t first_cluster_low = (uint16_t &) dir_buf[0x1a];
uint32_t first_cluster = (first_cluster_high << 16) | first_cluster_low;
uint32_t file_size = (uint32_t &) dir_buf[0x1c];
uint32_t n_clusters = (file_size + bytes_per_cluster - 1)
/ bytes_per_cluster;
cout << "file_size=" << file_size << endl;
cout << "n_clusters=" << n_clusters << endl;
ofstream fout("/tmp/TRK02.WAV", ios::out | ios::binary);
vector<char> cluster_buf(bytes_per_cluster);
for (uint32_t i = first_cluster, j = 0; j < n_clusters; i = fat[i], j++) {
cout << j << '/' << n_clusters << '\t' << i << endl;
assert(i != 0 && i != 0xffffffffU);
if (j < 2) {
// write first 2 clusters of TRK01.WAV
fin.seekg(header_size + (i - 2) * bytes_per_cluster);
} else {
// TRK02.WAV is 2 clusters after TRK01.WAV
fin.seekg(header_size + (i + 2 - 2) * bytes_per_cluster);
fin.read(&cluster_buf[0], bytes_per_cluster);
assert(fin.gcount() == bytes_per_cluster);
fout.write(&cluster_buf[0], bytes_per_cluster);
cout << endl;
int main() {
Fat32 fat32;
fat32.read_file("TRK01 WAV", 0x14c9f840);
// fat32.read_file("TRK03 WAV", 0x14c9f880);
// fat32.read_file("TRK04 WAV", 0x14c9f8a0);
// fat32.read_file("TRK05 WAV", 0x14c9f8c0);
