Guys, i need your help. We are trying to do multi track recording from a Sq6 console… all our instruments and vox from the stage are connected via slink… what we need todo to route all this channels to the 32x32 usb B or sqdrive recording?
First timer here…
what we all know from knowledge based that we use the tie lines…we tried but no success… can someone give detailed instructions? Appreciate your help
Hmm, too less information.
To narrow down the possibilities you should tell us what you tried so far, why i failed and which sources of knowledge you have used. (Manual, videos, articles …)
Furthermore you should also tell us which DAW you are using on which operating system. Also your DAW setup is from interrest.
As of now. We are recording from SQ drive using the Main LR mix… we plug SSD drive in the console… we want to record the multitrack on the console so We tried to bring other channels like vox 1 2 3. Guitar. Bass. Drums…etc… but whenever we patch it to the USB we loosed the sound on the Master…
However. In multitrack.we only get…
Channel 1. MAIN L
Channel 2. MAIN R
Channel 8. Local input (mic)
We have Adobe Audition for DAW. But not yet used since all the channels still missing.
but whenever we patch it to the USB we loosed the sound on the Master..
that indicates that you are not patching tie lines
or you are patching USB to USB or something similiar
@Aries are you trying to record the Master/Main to the SSD (SQDrive) and multitrack on the computer? This is not possible with the SQ. Either SQdrive or USB B, you have to choose.
But you can setup the usb out routing to record, for instance, input 1 to 30 on USB channel 1-30 and Main LR to USB channel 31-32.
Thanks to your reply. We will try all this and update you guys…
Have you guys tried to record multitrack in SQ6 console? How did you do it? Can you make quick list of the procedure? Let say from start…
Appreciate your help… thanks a lot.
Look at the picture I sent.
Step 1: I/O Patch
Step 2: Outputs
Step 3: IP Direct outs (on the left)
Step 4: USB (on the top)
Step 5: Patch (this will send a direct output of whatever is going to the input channel)
Step 6: Routing Tab
Step 7: There should be a button that says direct out
Step 8: You can choose the direct out settings and where the source is from
P.S the board comes with a manual (:
Thanks a lot guys for your helpful replies… i will test all this info of yours… appreciate your help…
@Nudgy, i think this is what i need… i will keep you posted… We do our recording every thursday for online Worship Service. and the venue and equipments are rented place.
@aries
if you are renting venue and equipment I would ask them for help using it
@volounteer, yeah agreed… but the sound guy… he also haven’t tried it before… weird, right?
Hey @Nudgy. , It works… Thanks a lot :-). We can record now multitrack from slink using Audition…
yay! I used to use Tracks Live but macOS Catalina broke it; so I went to reaper.
-Adam
