Multitrack recording not seeing 4 channels
I’m running a waves card in a DLive C1500 for multitrack recording during a live show. All channels are are fine for the show but channels 4 thru 7 aren’t hitting the computer even though they are routed on the virtual soundcheck tab. All other channels are getting to the computer. I’ve tried 2 different DAWs with the same result. I am using a windows computer with Soundgrid QRec.
Any idea what the problem could be?
Thanks for your help.
Eddie
Have your verified the patching on the Soundgrid side?
Hi Chris,
Yes, I have. I also tried send those inputs to different channels in the DAW but still got no input.
Eddie
It sure sounds like a routing issue. It could be on the DLive side or the Waves side.
I would suggest that you triple check a couple of things on the DLive side. Are you really using the virtual soundcheck functionality or are you really sending the channels out as “direct outs”? There is a different routing tab for each type of output. You might have channels 4-7 routed correctly in the VSC tab, but not the direct out tab, or vice versa.
I’m not familiar with how to route things on the Waves side, but triple check those settings/tabs as well. Again, it might have been set up correctly at one time and then something borked channels 4-7 and you shouldn’t assume it is set up correctly.
I can confirm that things get weird if you have direct outs and VSC set to use the same output. I don’t remember which one “wins”, but it’s the one I forgot I had turned on.
