Mute for Scene Safe channel
Quick question. If a channel is scene safe should, should Mute be preserved from the previous scene?
If a channel is scene safed that means that it is “immune” to scene recalls, or that scene recalls will ignore that channel.
If a safed channel is muted and you recall a scene where it would be unmuted, it will stay muted, because it is safed. You can go into the scene safe matrix and set up very specific safe parameters so you could have everything on the channel safed, except for the mute button.
You can also do this on a per scene basis with the recall filters.
Chris
The current state of the channel will not be altered by scene safeing it, all that will happen is that subsequent scene recalls will not affect that channel.
Chris
